Manual Design and Adjustment of Custom Print Report Templates
Designing Templates
Adjusting Templates
Image Upload and Signature Fields
If the Image Upload or Signature fields do not output correctly, you can download the default template again. If re-downloading the default template is inconvenient due to using a custom-designed template, refer to the following methods:
Since Image Uploads and Signature fields are output as images, you cannot directly reference the fields in a template by entering {d.field_id}. The correct approach is as follows:
2. Copy the corresponding image upload or signature field from the default template (the field will display an image with the text "This is a TEMP IMAGE"; make sure to copy the entire column).
3. Paste the copied field image into your template. After uploading and saving it as a custom print report, the image upload or signature field will display correctly.
1. Open your custom template. At the location where you want to insert an image or signature field, upload any image from your computer.
3. In the "Alt Text" description field, enter the field syntax(refer to the Field Value Syntax Reference) for the image upload or signature field from the sheet in the format {d.field id}.
Notes: The Image Upload field only supports single-image selection and does not support multi-image settings. If you have already adjusted the field settings, you can either download a new default template or update your template by following the steps outlined above.
Top of Page
    Start Ragic for Free
