Manual Design and Adjustment of Custom Print Report Templates
Content
Designing Templates
Adjusting Templates
  Image Upload Fields
  Signature and Barcode Fields
  Free Text Fields
  Using BBCodes
  Displaying the Print Timestamp
  Appending PDFs from File Upload Fields
Designing Templates
Currently, Word, Excel, and PowerPoint templates are supported. It is recommended to start by downloading the default template from the Custom Print Report settings page before making manual adjustments. You can then modify the table's background color, borders, positions, and add titles, text, or images as needed. Be aware of the different syntax for independent fields and subtable fields when adding or removing fields.
Adjusting Templates
Image Upload Fields
1. Single-Select Image Upload
If the Image Upload field is later modified to allow multiple images, be sure to download and use the latest default template. If it is inconvenient to re-adjust the template, you can instead add IMG:html to the field syntax. (Excel and PowerPoint templates are not supported.)
Note: If only one image is uploaded and "Max Height" and "Max Width" are not specified, the image will default to 300px × 300px. If specified, the image will be displayed according to the defined settings. For multiple images, the system adjusts each image’s size based on the total number to avoid layout issues. As a result, the more images uploaded, the smaller each image will appear, and they may not follow the exact specified size.
3. Output Blank Field
If the image field is empty and the downloaded file displays the field as shown in the image below, please edit the image field’s "Alt Text" in the template by adding {field_parameter:ifEM:drop(img)}, then re-upload the template.
Free Text Fields
Using BBCodes
If you use BBCodes in a Free Text field or apply styles in the Rich Text Editor and want to retain the formatting when exporting, you need to adjust the field parameters accordingly. (Excel and PowerPoint templates are not supported.)
Please refer to the table below for the explanation of two available parameters:
Parameter Format html Format html(inline) Format
Example {d.1002578:html} {d.1002581:html(inline)}
Supported BBCodes br, b, i, u, s, li, ol, ul, img, url, color b, i, u, s, color (Does not support URLs, images, or any BBCode that creates line breaks)
Suitable For When full styling is needed and field values require line breaks (e.g., paragraphs, lists) To display only basic styling and keep the field value on a single line due to specific layout requirements.
Example:
Export the record in the image below using two different parameter formats to produce the following output.
html Format
html(inline) Format
If you want the printed file to show the current date and time, add the following parameter to the template: {c.now:formatD('YYYY-MM-DD HH:mm:ss')}
Notes:
1. For available date and time formatting options in formatD(), please refer to this page.
2. Use "single quotation marks" in the parameter, and only use ', not .
3. The time will be displayed based on the time zone set in your Company Settings.
By adding specific parameters to your template, you can append the PDF files stored in designated File Upload fields to the final exported PDF document. You may choose to place the appended files at the beginning or at the end of the output. The following examples assume that the field parameter for the File Upload field is "d.1234567".
Append to the End
Add the following parameters at any position in the template:
{d.1234567FILE_URL[i+1]}
Append to the Beginning
Add the following parameters at any position in the template:{d.1234567FILE_URL[i]:appendFile(start)}
After uploading the template with these parameters, all PDF files uploaded to the specified field will be appended to either the beginning or the end of the final document.
If your sheet includes multiple File Upload fields, simply apply the same parameter format to each field as needed. You may configure some fields to append their files at the beginning of the document and others at the end, depending on your requirements.
Note: The maximum file size after appending is 100 MB.
