Learning Center
Configuring Approval Flow
7 mins
What Will You Learn?
  • Create Approval Flow
  • Approval Rule Settings
  • Add Multiple Approvers
You may configure the Approval process on all the sheets in Ragic. When an approval flow starts, the system will automatically send e-mails to the approvers. They can approve or reject the process in the Ragic database, e-mail, or mobile app. Besides, you can set up rules for the approval flow. For example, submitting to general manager only when the order amount due is larger than $50000.
We also support Adding Multiple Approvers in the same step or Setting a Threshold for Approval.
Related Documents
Approval flow configuration
Completed this course? Check the checkbox below!
I've completed the course!
    Loading...
